The JR Sport SX600 6-channel MD2 radio system (JSP16000**) has an awful lot to offer for $159.99 suggested retail:
Digital computer precision
Easy-to-read LCD screen
10-model memory
Trainer system
2 conveniently mounted direct-access programming rocker switches
Computer designed ergonomically styled case
Adjustable stick length
Dual rates for aileron and elevator
Digital trims with Direct Access feature
Throttle trim only affects idle position
Two-speed scrolling—press and hold the appropriate button to scroll quickly or press and release to scroll in steps
Flaperons mixing
Delta wing mixing
V-tail mixing
Throttle cut safety feature
You can read the owner's manual here:
http://www.horizonhobby.com/ProdInfo...600_manual.pdf
This radio is only slightly more expensive than a standard 4-channel entry level setup, while offering a lot more advanced features. Of course, you can always get a nicer radio for more money. A top-quality 8-channel setup with glider and helicopter functionality and a complete feature set is available with the Airtronics RD8000, which is about $100 more expensive than the JR Sport SX600 system. Both of these radio systems are fantastic values when compared to anything else in their price ranges.
