RCU Forums - View Single Post - Tip Plates?
Thread: Tip Plates?
Old 01-27-2003 | 07:41 AM
Selcuk
Default Tip Plates?
I tried winglets on my learjet which has its cg at leading edge of the wing. I put the up winglets with an angle of 30 degree angle with the up surface of the wing but it did not prevent to stall at low speed. As I understand you said down winglet is more effective. I can change it. Do you advise me to do that? And do you have any size recommendation?
