RE: G-26 Engine problem
yeah it is the Ultrastick lite 120. A friend of mine did the job of the G-26. It involved moving one servo all the way to the very end of the tail and chopping the nose off. It has tremendous power, but is very touchy. I think it is a mixture problem. The lag shows in power as well as sound. It is really responsive at low altitude and on the ground, but above 100 feet or that far away.... you can see that it gets worse with the increasing distance. The other controls are not like this... they work perfectly.
So Should I work on low as well as the high end? I have always heard that the low end mixture is the transition mixture. Advice?
Bill R.
