Can I use the 3101's for the Ailerons or are they to long. Thanks for these links these look like the right Ni-cads and Upgrade motor. About the NIMH batteries for $21 do you get two packs for $21 so you can charge one while flying with the other alternating them or do you just get 1 pack for $21. Or do you use both packs at the same time in the plane.
One thing I also heard is that the combination NIMH,NICAD Lithium battery chargers are no good. To just get seperate
Lithiam and NICAD,NIMH chargers for field charging. What have you seen on the field. Or are the combo chargers just 2 different chargers in one box.
Like the Multiplex Charger Li-NiCd-NiMH on this page
http://www.maxxprod.com/mpi/mpi-9.html
