RE: E-FLITE BLADE CP PRO
Just ordered the super-skids..
I have been suspect of the set screw in place of the shear pin... can you cross drill a shear pin hole perpendicular to the set screws?
Hole is so small, it shouldn't degrade the strength at that point...
By the way, on the plastic head, where you using a paper clip or the stock steel shear pins.
