ORIGINAL: djheptic
i need to shim my rear diff. what shims do i need 0.5mm? or 1.0mm?
The only shims I know of come with the spider gear cup or the HD final gear set and as far as how thick or how many it varies as one might be different then the other. They only have one size that comes with the HD final gear set to shim the ring gear assemble but the spider gear cup comes with both for the ring gear and pinion gear.
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
