RE: Micro and Mini servos what to use
I'll pick up the two Nicad packs that's a really good deal.
Can you hook up the Triton 2 to a car battery to charge the packs or only a gell 12volt. Or charge the Gell with the car battery.
Also can you use a power supply if you want to do in house AC charging or will the charge not be accurate with a power supply than a 12 volt battery.
Or is the Triton made with a AC/DC version. Any other quality AC/DC Multi charger on the market.
