RCU Forums - View Single Post - Lathe for conversions
Old 12-18-2006 | 07:10 PM
  #203
captinjohn
Default RE: Lathe for conversions
New Question: Several conversion engines have a flat area with 4 holes taped for a recoil..ect. If this flat surface is placed on mill table with the prop hub pointed strait up...will this give a good setup to mill the prop hub to a true surface? Also If mill cutter is running clockwise..would you turn hub counter clockwise when cutting. How is this done? Thanks Capt,n
