RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 12-18-2006 | 07:30 PM
  #366
choppersrule
Default RE: E-FLITE BLADE CP PRO
Robmoney,
For what it's worth, I've been using paper clips on the plastic heads for several months, also, I have the 7.5 amp fuse on the main motor. Between the two, one backing up the other, I think it would be extremely difficult to fry a 4n1. Also, with the paper clip trick, I've never busted a main rotor or blade grips either, the paper clip snaps and saves it all. You may have seen my earlier post with picture of a pair of busted carbon fiber blade, paper clip snapped and nothing else damaged.
Dave / Choppersrule
ORIGINAL: robmoney
Just ordered the super-skids..
I have been suspect of the set screw in place of the shear pin... can you cross drill a shear pin hole perpendicular to the set screws?
Hole is so small, it shouldn't degrade the strength at that point...
By the way, on the plastic head, where you using a paper clip or the stock steel shear pins.
