RE: Built an impeller(Brass) :)
Prop Sharpening and balancing.
well that prop looks a little uneven in lots of spots and it looks about the same size as your real impeller. once you balance and sharpen it it is be smaller then your impeller and there for make lots more slippage.
i would suggest if you make another then make it a little but bigger.
and when you bend your brass. use your hands . its more a even curve.
