RCU Forums - View Single Post - Help me select my trainer
Old 12-19-2006 | 08:50 AM
Fastsky's Avatar
Fastsky
Default RE: Help me select my trainer
Re: "Does the wings on the LT-40 easely disasembled for convenient transport ? " < No! The 2 wing halves are epoxyed together and then the joint is fiberglassed about 6" wide (3" on either side of joint). If you are really sure that a 70" wing won't fit then look at something smaller like a Tower Hobbies trainer. Midwest has an Aerostar that is a bit larger and its a nice trainer. All the trainers will fly similiar enough to learn on. If you can get some flight sim time before going to the field then a Hobbico Avistar would also probably work for you and its on the smaller side. [8D]
