RE: Elete 4500
That sounds decent 1.4v. Remeber, the more use the batteries have on them, the higher the voltage will get. Newer packs will get around 8.8V and then start climbing with more use. As the voltage goes up during a charge, the mAh will go down. The quicker heat is generated, the more resistance is created, and the less of a charge (mAh) you get. If you have a bad cell in a pack, you voltage might be low also, but the heat will be the giveaway,,,,,really high.
