ORIGINAL: Fastsky
< No! The 2 wing halves are epoxyed together and then the joint is fiberglassed about 6" wide (3" on either side of joint). If you are really sure that a 70" wing won't fit then look at something smaller like a Tower Hobbies trainer. Midwest has an Aerostar that is a bit larger and its a nice trainer. All the trainers will fly similiar enough to learn on. If you can get some flight sim time before going to the field then a Hobbico Avistar would also probably work for you and its on the smaller side. [8D]
In fact I mean, can you detach the wing easely from the fuselage ? If I can remove the wing from the fuselage, then I will be able to carry them alongside of the fuselage but if they need to stay attached then it's a problem for me.
