RCU Forums - View Single Post - Epoxy question
Old 12-19-2006 | 03:50 PM
MadScientist
Default RE: Epoxy question
Epoxy, like every other type of glue, soaks into the wood fibers. the longer the soak, the stronger the bond, typically, which is why your isntructions called for the 30 minute epoxy. Since it's not a plane that's going to see terribly high stresses, like a much faster or aerobatic plane would, I think you're fine with what you have.
