RCU Forums - View Single Post - Evolution 58GX
Old 12-19-2006 | 04:55 PM
bodywerks's Avatar
bodywerks
Default RE: Evolution 58GX
Yeah, it works so well that it will fire your engine up without you touching it! If You go Evolution, be careful. The ignition system emits several sparks over the course of a full second as soon as you turn on the ignition, for pretty much no reason whatsoever. So be very careful about where you are when you reach back to turn on the ignition, as well as where the piston is in the cylinder or you will get bit!
