Creek Hobbies extra 330 servo location
on the lighter engines the os-160 the flyers are needing nose weight you may come out w/out any weight needed seeing how the moki is heavier. those flyers put their servos in the tail with one servo on the rudder on a pull pull set-up. i have one that i need to work on w/os-160 i will be installing my servo as per above described.....
