RCU Forums - View Single Post - Lathe for conversions
Old 12-19-2006 | 08:47 PM
  #208
captinjohn
Default RE: Lathe for conversions
RCIGN1: Please take a look at photo of engine in post 204. I found out the mag is not going to work that well. The amount of stock holding the magnetic coil part is not going to support it good. On the engine you done like this one did you use setup on back of engine for timing or is there a better way. Also will this engine start and run on fixed 28 degree ignition timing? Thanks Capt,n
