RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 12-19-2006 | 09:58 PM
  #5623
gjeffers's Avatar
gjeffers
Default RE: U-Can-Do 3d 46?
ORIGINAL: mnrcaerobat
I just picked up a UCD 46. Will the Saito 100 be too much? What should I use for servos? I think I will be using standards and a HS-5625 on rudder. Any build tips?
the 100 is a great engine, i use a 15x6 apc on mine, will hover great.balance will be easy, i have my rx and battery right behind the fuel tank and it balances at 5.5in behind leading edge.
you will want to beef up the LG a little, i just drilled a couple holes horizontally through the LG block and ran in a couple of peices of allthread with a little epoxy in the holes and on the threads and its still all together.
(pic below)
your servo selection will be fine.
just mount the engine as far forward ao the mounting lugs on the engine are even with the end of the mount, you may have to sand(dremil) off a little of the mount where the bottom left mount screw goes.
any more questions just ask
ID:	580400   Click image for larger version
ID:	580401   Click image for larger version
ID:	580402   Click image for larger version
