RCU Forums - View Single Post - Official HPI MT2 Thread
Old 12-20-2006 | 08:29 AM
  #10380
nickrummy's Avatar
nickrummy
Default RE: Official HPI MT2 Thread
I've run the 2 speed in my truck. I couldn't agree more with rcnz, if you are looking to upgrade to a .18 motor GET THE OS .18 CV-RX. It is a WAY better motor than the 18ss motor. If you get the OS motor it would beat an MT with a T15 motor and 2 speed tranny easily.
I ran the 2 speed in my truck with my OS motor and it was crazy. Lots of low end and lots of top end. Fun truck to drive. Problem is, the 2 speed tranny does not have a slipper setup so your drive train is completely locked in when your clutch shoes are spinning the clutchbell so when you land off a jump with your motor revved you will be breaking parts or stripping spur gears.
If you are planning on running onroad and that is it, then the 2 speed would be fun to play with. If you are going to drive off road at all, stick with the single speed. Either way you go, get the OS .18 CV-RX, you won't be sorry!
Here is the 2 speed I used
http://cgi.ebay.com/HPI-2-Speed-Tran...QQcmdZViewItem
Here is the clutch bell I used.
http://www2.towerhobbies.com/cgi-bin...?&I=LXM729&P=7
and you would need this pilot shaft to run it
http://www2.towerhobbies.com/cgi-bin...?&I=LXM721&P=M
and run this racing clutch. It's awesome.
http://www2.towerhobbies.com/cgi-bin...?&I=LXLW03&P=M
ORIGINAL: dnizzle2
im new to these forums....i was just curious what you guys think of the 2 speed for the mt 2? where can i find one that will work and do i have to do any modifying to install it? also does the 18 ss add bottom end and top end? maybe the better question is...would a 18 ss make it as fast as a 2 speed. thanks
