RCU Forums - View Single Post - Lathe for conversions
Old 12-20-2006 | 12:56 PM
  #213
Antique's Avatar
Antique
Default RE: Lathe for conversions
Green Loctite 680 stud and bearing mount on the threads...The normal rotation of the engine tends to keep it tight if the Loctite should ever get hot enough to loosen...Takes over 400 degrees...The green Loctite on a 4-40 carb disc screw holds so well that the head of the screw will twist off before the Loctite loosens...
