RCU Forums - View Single Post - CX2 making circle, need help!
Old 12-20-2006 | 05:16 PM
tinchao
Default CX2 making circle, need help!
Hi, after reading all the Cx2 fan take their heli outdoor, I did my share of outdoor flying, some good day, some not too good, bascially is the wind. No patient! "NO CAN WAIT". Come on, man, when a grown man have a RC toy in his hand, that is what happen, knowing that the wind is a lttle to strong, but still go for it....... then....... "CRASH !!!!!"
After the crash, the heli started to act funny, when I hover and check the trim, the heli starts to make circle, the entire heli is making circle, not nose turn, just moving around and around. when it build momentun, it will make a bigger circle and go faster. Try to trim it , but can not fix all the "circle motion" Is that what you guy descripe as "Toilet bowl" ??
OK, here is what I did.
remove both up and bottom blades, check balance, OK, no problem
Check the metal bar on the top, it appears a little off, took it out and fix it the best I can.
My CX2 still like to make circle afte my limited repair skill.
Any suggestion what is the next step??? [sm=72_72.gif]
