RE: Magnum .40 2stroke issues...
I just acquired a Magnum SP .40 and had to totally clean before using. It has the older style carb which has an low end air mixture screw similar to the idle stop screw. Should the begginning setting on the idle airscrew be set at 3/4 turns from fully seated?
