RE: CX2 making circle, need help!
I found that if you screw the blades together, then balance the blade on the balls only, between two equal height coffee mugs works great!
I now have two pieces of wood 1x6 that are perfectly square!
Almost forgot!
Tighten the screws in the collar that holds in the upper shaft, and press the upper shaft down and the collar up as you tighten screws!
Good luck!
