RCU Forums - View Single Post - 3W 55i problems
Old 12-20-2006 | 10:00 PM
Antique's Avatar
Antique
Default RE: 3W 55i problems
Carb needles don't drip fuel when the carb is working correctly...Most likely cause is the inlet needle not seating...You should get the carb checked with a pressure gauge, it should hold at least 8 lbs pressure indefinitely...Small engine shops have the tester....
