RCU Forums - View Single Post - Epoxy question
Old 12-21-2006 | 06:40 AM
rrragmanliam
Default RE: Epoxy question
ORIGINAL: gboulton
You're going to hear both opinions, I'm sure. IMO, I'd re-do them with 30 minute epoxy if that's what's called for in the instructions.
If you do decide to redo the wings, then it shouldn't be too difficult to take these wings apart. Get a covering heat gun, and go over the joints slowly to heat them up. As they get warm, wiggle the joints carefully until they start to loosen up...with a bit of patience, you'll be able to pull them apart....the heat will soften the epoxy. Once they're apart, do some sanding to remove the old epoxy and clean up the joints, and then re-glue them using the "correct" epoxy.
You may have to do a bit of recovering around those joints as well, as the heat may damage the existing covering.
Speaking of IMO this is horrible advice. Debonding epoxy is a pain in the rear, not to mention all the extra work associated with the process (heat, wiggle, sand, reglue, recover). There's a good chance you will break a rib at the bond joint and then you can add rebuilding to the list.
The five min will be fine, just remember to use 15-30 min in the future as it will give you more "cure time" to get your parts lined up
correctly as Old Scale Guy mentioned.
Darren
