RCU Forums - View Single Post - ignition problem?
Old 12-21-2006 | 09:01 AM
ShineyObject's Avatar
ShineyObject
Default RE: ignition problem?
Yes it does Silver and that is part of what I will check out after the holidays.
McQuinn - thanks for addressing my real question.
I believe the problem will be one of the two items brought up. Something is loose in the electrical, or the EI is bad. I'll try to remember to post the final solution here.
ORIGINAL: Silversurfer
Starts and runs good on the ground, then quits in flight, returning to the ground and it starts and runs well again. Doesn't that sound more like something loose? A broken wire that loses connectivity when moved? A loose wire at the plug cap? Wire at a switch or battery? Sounds to me like the ignition is probably working just fine by itself, but something is interrupting the flow of electricity to the end point.
If everything in the ignition checks out the you'll need to revisit the fuel system to see if it's venting properly.
