RE: Help with getting started.
Tucking the rudder full under means that the bottom leading edge of the rudder is towards the hull. This creates a lifting effect, pulling the transom up out of the water. With the stock rudder, this can only be done a couple mm. You don't need that much adjustment here. This adjustment will either help or hurt cornering.
Welcome Baboon. A new Grimmie........maybe.
