RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 12-21-2006 | 01:36 PM
  #1032
av8tor1977's Avatar
av8tor1977
Default RE: gas fuel with glo plug no ignition
Hi,
Yes, that's the mix we are using. As far as the carb, the answer is "it depends". Some carbs will run rich enough with no modifications other than opening the mixture screws a bit; usually a half turn or so. Some carbs don't want to get rich enough unless you raise the lever for the metering diaphragm just a touch. Also note that we are using a good quality four stroke glow plug.
Good luck and have fun,
AV8TOR
