RCU Forums - View Single Post - CA glue
Thread: CA glue
Old 12-21-2006 | 05:28 PM
fastinated
Default CA glue
Ok here go trying to use my thick CA glue only to find it's dried up.. once again... But I think my problem maybe stemming before it dries up. I don't keep this on my bench I keep it in my field box. In a perfect world it would never fall over and put glue back in the tip.. So usually when I use it I have to drill the hole back out or cut some off the tip.. So for me it's either or... I've tried leaving small nails in the hole, cleaning the tip after I use it. Do you guys that leave it on the bench does it last a while? I can't count the times this has happened over the years. Only my thick CA.. Thin stays fine, don't usually have medium. So figure it's only a few bucks, but either driving to the LHS (add the price of gas) or waiting for an order.. I'd rather have a better solution! Also how do you guys feel about the CA accelerator?? I've used it several times, but to me it seems that it may remove some of the strength b/c it's an instant thing...
Todd
