RCU Forums - View Single Post - tiger 2 restoration
Old 12-21-2006 | 07:56 PM
overbored77
Default RE: tiger 2 restoration
Thought i'd share a few more pics of my tiger, first one is when I got to field, second is after 2 flights, third was taken an hour ago. had to rebuild the front of the fuse again and some minor damage to the L.E. of the wing. after the holidays I will get to covering it. also on the tiger there is a piece of dowel that connects both halves of the elevator and I found out that was broken, I am adding servo controol horns and a double pushrod system so I don't have to uncover the tail feathers and also it will be alot stronger.
A quick question if I may, I had a tower.40 from my trainer in this plane and as it was alot of fun I would like to put it back in my trainer. Which engine should I get for the tiger? I was thinking of either the OS.46 ax, TT.46 pro or the tower .46, any suggestions or comments would be greatly appreciated.
ID:	581496   Click image for larger version
ID:	581497   Click image for larger version
