Originally posted by archer
I just put a clamp on the end of the wing and aileron to keep it from moving, then measure it. You normally have a threaded end on one side of the pushrod for any final adjustments.
In this case your suggestion doesn't help because the aileron is full length. But thanks anyway.
I need a UCD owner to provide me a vertical measurement from the inboard edge of the aileron to the bottom of the fuselage with the airplane turned on and the ailerons in the neutral position.
Scott
