Originally posted by scott hayden
In this case your suggestion doesn't help because the aileron is full length. But thanks anyway.
I need a UCD owner to provide me a vertical measurement from the inboard edge of the aileron to the bottom of the fuselage with the airplane turned on and the ailerons in the neutral position.
Scott
What I did was sight along the center of the wing tip and center the aileron along this line. I feel the exact measurment you are looking will vairy from plane to plane once trimmed out in the air.
