RCU Forums - View Single Post - throttle response
Old 12-22-2006 | 12:20 AM
tkg
Default RE: throttle response
Its most likely lean, To check for lean just pinch the fuel line and see if the engine just slows down and stops (lean) or if it speeds up and then dies (rich)
Or you have the throttle butterfly backwards, with the throttle closed and looking from the choke side you should see the threads of the screw that holds the butterfly
