RE: Dealing with boomstrikes
yea good old plastic blades.....thats one reason why I will never use plastic blades, too heavy and it just transfers the damage to other parts.
If you want to keep the plastic blades you can add some shims to the o-rings in the center hub. this will make your blades less likely to flex up and down.....but it can also make it a little harder to control.
