RE: Help problem with tail servo
Hi
Is there any way you can adjust the links above the swash plate so the plate will sit level and trims centered on Tx with no drift?
When taking off like I said above I have to give quite a bit of right to hold tail will this go away when flying or do I have to trim it right over giving me less right and more left travel?
Also whats the point in leveling swash plate and centering tail if I have to adjust them all out of line again to get it to lift off straight?
For give my ignorance as I am a newbie who jumped in and bought a 36 6 channel thinking I will pick this up through persistance only to find this site afterward which explains what I should not have done. But if you can help me trim this thing up ready to fly after I have learnt to fly the vortex 37 4 channel I have just ordered.
Thank you.
