RCU Forums - View Single Post - HELP PLEASEEEEE
Old 12-22-2006 | 07:48 PM
ehroof
Default RE: HELP PLEASEEEEE
when you apply the brakes can you look in the carb and see if closes completely when you apply the brake. if so you need to open the idle screw and set the trim more twards center or foreward. if it stay open then you need to replace the clutch spring.
