RCU Forums - View Single Post - Curare build
Thread: Curare build
Old 12-22-2006 | 07:50 PM
rainedave's Avatar
rainedave
Default RE: Curare build
Dean, I look forward to your build!
Here's an issue that arose on the MAN plans a while back. The root chord on the wing plan view is confusing. In a past thread I drew this diagram showing the actual outline of the foam core (blue and red lines), which isn't actually drawn on the plans. The green line shows where the core can be relieved for a solid wing bolt block. Compare the length of the red line to the chord of the root template on your plans. The red line is the correct root chord.
