RCU Forums - View Single Post - Pull-Pull Wheel
Old 12-22-2006 | 08:05 PM
Texas_Flyer
My Feedback: (15)
Default Pull-Pull Wheel
I am putting together my first pattern plane that has pull-pull setups (rudder and elevators). There seems to be lots of discussion about getting the pivot over the hinge, wires too loose/tight, etc but I have not seen many people using a pull pull wheel like this one: http://www.hangar-9.com/Products/Def...ProdID=HAN3515 It would seem that this would be the ideal way to set up pull-pull - wires don't move laterally as the arm moves, you avoid the mechanical exponential, you only have one wire to adjust, etc. But I don't see many people using this setup. What are the pros and cons of using a pull-pull wheel?
Alan
