ORIGINAL: rclement
Have fun with your U Can Do build. It's been the funnest plane I've owned.
I make my own rods out of carbon fiber tube and 2-56 rod ends. I'm sure they're not as good as the Central hobbies ones but I can the components at my LHS. Don't know if anyone mentioned but you'll want to beef up the landing gear too. Gjeffers has pictures of how to do it. It's very easy to do and needed. I never did install the tail wire set up. Kept forgetting to. But I've owned 3 Do's and never needed them. [insert: knock on wooden head : here]
The Do's are the best plane around and since I'm the only one at my field that flies one I look like a genius. [X(] I'm sure that would change if Gjeffers, Barry and Ron showed up......[>:]
Here's some pics of my Do......
What did you use at the ends of your cf rods? I have had problems with the smaller rods wanting to split in the past. I have used shrink tubing over my cuts.
