RE: EZ start trouble
Ok so i just got it started. Problem is i had to prime it for a while and when it started running for about 5 seconds it turned off. I think i have a compression problem, but that still doesnt explain the glow plug wire not working. I also took the cooling head off to check if it was on right cause i chipped the cooling head the day before it stopped working. Now that i cleaned it and tightend everything up, whenever i try starting it, it starts to smoke up. Im really confused now.
