RCU Forums - View Single Post - Pull-Pull Wheel
Old 12-23-2006 | 11:19 AM
grotto2's Avatar
grotto2
Default RE: Pull-Pull Wheel
You are correct that it is a common misconception that arm length has to be the same on both ends. It does not.
But I still maintain that if the holes of a 'classic' rudder horn are lined up with the hinge you will get slack with a round servo output disc like the one abuckner asks about. That wheel has a slot around the edge that holds the cable like a reel.
You can build a model of the round-wheel-to-arm setup to see the result or better yet use a drawing program that will show dimensions such as Corel or Visio.
