RCU Forums - View Single Post - e-flite cap 232 bp
Old 12-23-2006 | 11:38 AM
wind junkie
Default RE: e-flite cap 232 bp
Have you guys seen the Accel Hobbies Cap 35 ES:
http://www.billyhellrc.com/capE.html
Mine is very good at everything. One thing I love about this plane is it won't drop the tail in inverted harriers. I need practice on those, and this plane really helps. Also, it's unbelievably durable! There is generous carbon reinforcement built into the fuselage. I've dorked it so many times nose down and cartwheeled it on many botched low KE passes, and aside from dislodging the wing (a 2 minute fix with more CA), I haven't had any damage yet.
I'm using a Hacker 20-20L, Hyperion 1200 3S packs and an APC 10x3.8 SF, HS 65's all around. Flying weight is 19 oz.
I find its perfect for lunch breaks even on breezy days when you can't keep a foamy in front of you. This plane has punch, and legs, so you can do whatevery you want in most weather conditions. I get many comments on how nice it looks too.
