RCU Forums - View Single Post - TACH READING HELP
Old 12-23-2006 | 01:09 PM
perreback
Default RE: TACH READING HELP
I doubt if the different readings you get actually depend on where in the prop arc you point the tach. Tachs can give you wildly erratic readings sometimes. Try sitting in the shade with the front of the plane pointed towards a sunny area of your field. Sit behind your plane when reading your tach --- safer than in front.
