RCU Forums - View Single Post - Senior Telemaster info
Old 12-23-2006 | 03:39 PM
skyhawk172n
Default RE: Senior Telemaster info
I'm at work so can't give exact weight, but a good guess would be 8-9 lbs. Mine has an OS 120 4 stroke soft mounted, 16oz. fuel tank no wing or tail bracing, but never flies at full throttle unless the nose is vertical up! 25 min. flights are where I usually give up, and with the bracing mods talked about, it should lift another 10 lbs of payload and still not cruise above 65% power. The fuse flexes, twists, and generally does everything a plane isn't supposed to do, except be loads of FUN!
Gonna build one someday with twin .91 4 strokes just for giggles...
Roy
