RCU Forums - View Single Post - Solo props????
Old 12-23-2006 | 04:34 PM
tahustvedt's Avatar
tahustvedt
Default RE: Solo props????
I'm using a three blade 20" Soloprop on a 1:6 scale p-40 at low rpm with good results, but I don't have anything to compare with apart from APC 17x10 Pattern with at higher rpm power system on the same plane. Mine's well balanced as long as the hub halves are tightened perfectly evenly.
