RE: gas fuel with glo plug no ignition
av8tor1977, I did a test run the homey with a mix that is as close to yours as I can get for now. I dont have any 10 10 glow fuel. I used 16% oil and 33% nitro. mixed 107oz of gas 21oz of glow fuel. If I did this right it works out to 31.5 to 1 oil ratio and 7.45% nitro per gal, and your mix is 28 to 1 oil ratio and 5.13 nitro per gal If I did this right???????? The motor ran great once it was adjusted with power on plug. At wot and power off rpms stayed the same , but at idle it would load up after a couple of seconds. My plug coil is incased in a metal shell so maybe it cant hold the heat at low idle? But does that mix sound right?
