RCU Forums - View Single Post - battery charging
Old 12-24-2006 | 02:44 PM
Got RPM's Avatar
Got RPM
Default RE: battery charging
yeah . you can charge the battery's in parallel. so you can feasibly do about 32 cells . it all depends on you MAX MAH it can charge..
Guver is absolutely right, this is very bad information. If the packs are in different states of discharge - which most would be - charging them in parallel is a great way to over-charge some of them, causing burst cells and ruined packs! Don't do it.
