RCU Forums - View Single Post - BME 110 Spark-plug diagnostic
Old 12-24-2006 | 07:43 PM
Albatross
My Feedback: (7)
Default RE: BME 110 Spark-plug diagnostic
ORIGINAL: pe reivers
Look here for plug readings [link]http://www.prme.nl/forum/viewtopic.php?t=10[/link]
Specs on the fuselage is not a mixture indicator. Look down into the plug where isolator meets plug body. If you see a black ring, the mixture is OK.
The black plug body is indicating a slightly rich mixture. Oil has little to do with that.
Placing the sensor on the front of the engine gives low temperatures. The prop turbulence forces the cool air deep into the finning. They should be placed at the rear, where the sensor is not cooled by the airflow. That is the main reason for the massive temperature rise after stopping the engine.
That's a good point, the air flow will give you lower temperatures.
After using the Hand held IR thermometer and the thermocouple sensors, another conclusion is that is very hard to say what is exactly the engine temperatures. I think depends, where you are measuring the temperatures, what are you using and when you are measuring them.
Thanks for the link to plug reading.
