RCU Forums - View Single Post - covering the holes
Old 12-25-2006 | 11:09 AM
tail strike's Avatar
tail strike
Default RE: covering the holes
dont heat it quite so much as to do that, and you can put a little pin hole in the covering on the bottom with a straight pin
I am watching you
larry S
ORIGINAL: vasek
Hi guys,
I have trouble with the covering (ARF) over the stab "lightenig holes"
when the air heats up t tends to stretch the covering> when it cools down> wrikles (again)
pls help,
V.
