Mechanical Retracts ,Pushrod Info
Note that any flexible type of pushrods that slide inside plastic sheath will not work when connecting the servo arm to the mechanical retracts. You need a solid piece of wire to push the cams in the mechanical retracts to the full up position. Plus, it takes a lot of torque to bring those wheels up. Any flexing in the wires could leave you with the wheels not fully locked in the retracted position.
